Trailleader
- Feb 9, 2023
- Wausau Wi
- 17 9000 stage 4
5000 miles on a track under hp
Throw it away when it looks like that
Just my opinion
Just my opinion
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Only putting new track on a sidewinder.Nice catch, Simplespeed... I never like to tell people when and how to spend their money, with that said I'd take a peek at marketplace you can get a track for 50¢ on the dollar. Not saying you're broke, Just saying.
I might use it this year, under the condition no high speeds were being ran.
Market place is the biggest scam ever.
Looks like time to find a ripsaw 2 with 1.5 lug.
I really like the taller lug for trail riding in my area.
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Understand,Tim. You'll be fine to ride that track. It just made the #1 spot on the list of priorities.Only putting new track on a sidewinder.
I use marketplace as a tool. If I can't go look at the product and see what I'm buying, I don't buy. 100% Everytime.
People buy this, buy that, then they don't like it, sell it for this....lol. world's full of them. Good luck, boss
REDLINE 1
- Sep 20, 2019
- ROUND LAKE IL
- 2018 TCAT
You running a 1” track on yr boost?Hmmm
You’re welcome
Lol
Ran 128 studs in t cats over 1/2 past lug in one inch track
More fun that 1 1/4 track on trail imo unless we received 1 foot of fresh snow
I ride groomed trails and race on the lake
It hooked on almost everything kinda like the boost bus length gapping the 998s in the videos
A little lug out of the gate on snow is good cause spinning ain’t winning
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Hmmm
You’re welcome
Lol
With the longer studs and less quantity how long till stud rip outs happen?
Doc Harley
- Oct 17, 2016
- Here & there
I probably wouldn't use the idea of 1/2"+ over for beast mode in the trails. Lol.
I'm guessing Trailleader is probably is a little more relaxed during trial riding excursions. Lol.
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
For those of you studding the middle of the track, aren't you hitting the center tunnel protector?
The last sled I had in my shop with the center of the track studded(ZR9000), the rear tunnel protector was all chewed up.
Maybe if you keep your track really tight this is not a problem??
I usually stay out of the center inch and a half of the track.
Trailleader
- Feb 9, 2023
- Wausau Wi
- 17 9000 stage 4
I run 1 inch on those and 998 and 1100You running a 1” track on yr boost?
Trailleader
- Feb 9, 2023
- Wausau Wi
- 17 9000 stage 4
Not as fast as the larger quantity of studs do.With the longer studs and less quantity how long till stud rip outs happen?
You have to ride like you have hp and not like they’re 600s.
REDLINE 1
- Sep 20, 2019
- ROUND LAKE IL
- 2018 TCAT
Interesting kinda goes against the old theory of too few studs more pullouts. But you can’t argue with the results. I’ve always thought to try the 1” with longer fewer studs. Seems like a win win with less weight for the track and studs vs the 1.25” track
Doc Harley
- Oct 17, 2016
- Here & there
I was under the assumption That less & longer studs would apply more forced to each particular stud.Not as fast as the larger quantity of studs do.
Can you explain your theory A little better?
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Sounds like
Doc Harley
- Oct 17, 2016
- Here & there
Sounds like
I think I used a woody's or Studboy template? I'm sure they wouldnt allow you to put any center studs in.For those of you studding the middle of the track, aren't you hitting the center tunnel protector?
Trailleader
- Feb 9, 2023
- Wausau Wi
- 17 9000 stage 4
lolSounds like![]()
You have to be aware of what you are riding on and keep up on maintenance.
I also think that the sled hooked up and not spinning as JT has now found on his is better than spinning and I believe spinning gives more a chance for tear outs or lugs ripped off like 1nc
Also easier to clutch and more consistent with less belt heat when not spinning.
I haven’t tore out a stud on one of my sleds since going this route in 2017
Stain is right on not studding center
The long studs aren’t for everyone
Doc Harley
- Oct 17, 2016
- Here & there
No, he's being honest. And he's fast. We just don't understand what's behind the madness.Sounds like![]()
- 13K
