Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Both of my ramps are freezing shut. What can I spray on the seals to keep them from freezing?
Thanks guys!
Thanks guys!
viper strike
- Dec 22, 2016
- belle plaine mn
- 2015 yamaha sr viper ltx dx
Try deep creep from seafoam.
Great penetrating oil.
That might work.
Other wise their is that lock stuff for car doors key holes.
That might work.
Doc Harley
- Oct 17, 2016
- Here & there
That might work.
I've thought of deicer. Just didn't know if it would deteriorate the seal. I'll try it.
I Google searched and found someone say, Pam cooking spray.
Anybody else use something with good results?
RAMSOMAIR
i use silicone spray
viper strike
- Dec 22, 2016
- belle plaine mn
If you use the deep creep it will actually condition the seals as well. Its a clear spray so you shouldn't see any streaking.I've thought of deicer. Just didn't know if it would deteriorate the seal. I'll try it.
Doc Harley
- Oct 17, 2016
- Here & there
I never thought to spray lock deicer on rubber. WD-40 & silicone have some amount of H2O or attract it.
I bought this stuff for locks. Sprayed all the rubbers with it today. Honestly, it looks promising.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Silicone or pam. I spray pam under my tunnel to prevent snow buildup. Any harsh chemicals might deteriorat the seals. That dry lube is probably silicone based so I bet it works.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
BTW silicone is good for rubber, that’s what o-ring lube has in it.
Doc Harley
- Oct 17, 2016
- Here & there
ClutchMaster, anything is better than two frozen doors and sleds sitting outside, and me waiting two hours for the sun to come over the trailer to thaw things out.
Doc Harley
- Oct 17, 2016
- Here & there
Try this ClutchMan.....
