Transfer blocks
I have blocks out but rod still in. I tightened my limiter straps 2 holes. In my opinion it balances out nicely setup like this. Transfers well but keeps the skis down and still maintains easy steering.
Pete, I don't and won't run large wheels and could not say whether they would hit or not. I would test it in the shop first with a block under the back of the rails only and have one realy big friend help you with compressing it down to see how close it comes to hitting.
How can you keep the front end down without the transfer blocks? Even with the blocks in, I can't keep the front end down on my sled. I put the Racewerx adjuster in to make quick adjustments.
Mike these rear wheels are not large,stock size,which is 8" on a 137 sled like mine.
Hi bro,i ran most of last year with just the rod in,but my rear arm did beat up the blocks quite a bit,but it does ride better with blocks out,and still steers good enough with straps out all the way,because of shapers I have on,but once I change out the shapers to woody,s I wont have as good control,and may have to pull the straps some.
