snowman
I put a transfer kit on my rx-1m today and now i can do wheelies
Anyone else try this :?: if so let me hear it.
Jonny Rocket
- Colville, Washington
- 2008 MXC boosted Nitro
I know of a couple people that have this. I was looking into but was a little concerned about ratcheting. Just a couple questions for you. 1. Do you have this ratcheting problem? 2. If not do you have extroverts and a clipped track? 3. What kit did you use? thanks, J
Never heard of this kit tell me more :shock:
Gilbey
Are you referring to the Quick Adjust Transfer Rods from Bender?
tmk50
No -
it is a kit that replaces the control rods with a rear limiter strap
3rd item down on this link:http://www.mountainperformance.com/yamaha_rear_suspension.htm
therxwon
i put the transfer kit on and i like my rx1 again, i also tried snowfevers mod .The rx1m should come stock with the transfer kit it works that well.and you save 5lbs.
BlgsRX-1mtn
- Apr 16, 2003
- Billings, MT
- '03 RX-1 Mountain LE
I have been thinking about doing this but have a question first. We all had a problem with ski lift early in the season. How does your RX-1mtn handle the corners when you get on it going down the trail with the kit? We all have to ride the trails to get to the pow and I for one don't want to end up in a tree.
therxwon
80mph down the trail, Simmons skis and a stiffer track for stoping. Its still works better then a summit or rmk.
snowman
With this kit i have noticed a slight decrease in ride quality but a improvement in acceleration,not much difference in ski lift(any worse and i'd be barrel roling the turns)
deerlodge
- May 1, 2003
- Orr,MN
- www.deerlodgeresort.com
snowman said:I put a transfer kit on my rx-1m today and now i can do wheelies![]()
I put the same kit in my mountain and I have studs,but I cant ever get the skis to come off the ground.Am I useing the wrong holes?
ski-bum
Sounds like a great mod for the deep stuff, but on the steep stuff in firmer snow I like to keep the front end on the ground so I can keep that heavy front end from falling off to one side.
