welterracer
Has anyone ever come up with a brass bushing to replace the stupid needle bearings Yamaha used in each end of the transfer rod? The parts are crazy expensive for this dumb little thing. Wondering if someone couldn't fabricate some brass bushings to replace them
DARKMAN
- Sep 27, 2023
- Harris, MN
- 2013 APEX SE
1981 ET340 "Frankenticer"
1982 SS540
1981 ET250 Mod Oval/Lemans Racer
I believe they use a Timken bearing or should be able to cross reference the number on the original to Timken, or find by dimensions, they are likely cheaper than what Yamaha wants.
RobX-1
- Coldwater, OH
$22.81 on Partzilla
welterracer
I found replacement ones on ebay for $10 each.. but you still have to replace the spacer and the seals on each side. This adds up. I would like to put a brass bushing in and eliminate it all together
TrueBlue
How long will these bearings last. (miles)I found replacement ones on ebay for $10 each.. but you still have to replace the spacer and the seals on each side. This adds up. I would like to put a brass bushing in and eliminate it all together
