X2. First pic is original tri-hub.Jt big wheel kit is a great option as well as Larson racing I believe. Great upgrade from the tri hub. May be something for you to consider down the rd. You do pay for what you get as they are more expensive then factory but will outlast by far.
I just put my blocks on #2 from the #1 setting and will give it some seat time. The front end is stay a bit more planted however it might be snow conditions. The skid seems a bit lose under acceleration.I didn’t remove mine. What I did do though was, I put mine back on setting 1. Had it on 2. It lets the front come up just a little more. I like it in the corners. I let off a little into the corner, then in the Apex I give it gas. Really like this setup now.
