Here it isCan you post the link where you bought the wheels...I found the axel. Thanks...great setup!!
Both are 15mm wide. OEM bearings are only 12mm wide. You need to order the Big Nutz axle for 15mm wide bearings or they won't fit.The website only shows your wheels in 20 or 25mm bearings...you say you have 15mm...did you have to call and special order??...thanks for the help.
