SumpBuster
- Jul 18, 2003
- Carlisle, NY .
- 18 sidewinder; 06 Apex RTX
I had a Cosworth Vega with bucket tappets and shims in the recess, but Chevy had a 'fork', and you would rotate the cams so the tappet you are working on was pressed down and then the tool would hold it down while you removed the shim and put the correct amount back in.You adjust gap by changing shims? You can't just turn a nut onto of the valve and tighten it down? That's how my friend and I did it on his diesel marine generator. Do you have to pull the cam to adjust? Or is that something else, and I'm not connecting the dots here?
musselman
- Apr 17, 2009
- Fenelon Falls, Ontario
- 2019 Ren XRS 900T, 2010 Nytro RTX
Yes unfortunately the cams need to come out to change shims, this is new territory for me so it may take some time. I have attached the excel sheet I used to record all of my valve clearances for reference. I still need to update it with the current shims to figure out what new shims are required.
steveg_nh
So the shims just wear out over time? Too bad they just weren't adjustable. ![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
musselman
- Apr 17, 2009
No the shims don't really wear at all, the valve and seat wear causing the valve to protrude further into the head which reduces the clearance between the cam and bucket.
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
Yeah, the cosworth shims were pretty hard!No the shims don't really wear at all, the valve and seat wear causing the valve to protrude further into the head which reduces the clearance between the cam and bucket.
steveg_nh
Ah I see. Thanks for explaining that!
musselman
- Apr 17, 2009
Got the cams out and removed the buckets and shims. Should I measure the shims that were in there or do they not wear? It's going to be tricky to get within spec on some valves since the replacement shims only come in 0.05mm increments.
steveg_nh
Holy crap that is surgery!
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
Absolutely mic them, especially where they made contact and adjust according to what you measured.Got the cams out and removed the buckets and shims. Should I measure the shims that were in there or do they not wear? It's going to be tricky to get within spec on some valves since the replacement shims only come in 0.05mm increments.
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
A work of art!Holy crap that is surgery!
steveg_nh
Very satisfying too!
musselman
- Apr 17, 2009
musselman
- Apr 17, 2009
Added a picture to view the measurements easier.
TBay Sledhead
- Jan 16, 2005
- Thunder Bay, Ontario.Ca
- 06 Attak
01 SXR Long Track
I'm having a little trouble interpreting your data. What are the no represent in the old shim new shim columns, is that standard or metric or some kind of part no.
musselman
- Apr 17, 2009
The shim measurements are shown in hundredths of a mm, this is the format that is shown on the shim itself, for example a 175 shim will measure 1.75 mm.
