Trying To Install Snowtrackers But They Don't Seem To Fit
woodynh
Moultonborough, NH
I just bought a pair of snowtrackers off e-bay. They are brand new and the package has the correct part number for a semi aggressive pair for an 06 Apex but they don't seem to fit on the skis. I am thinking they are not as marked or I need to make some modifications to my skis.
Any comments or help is appreciated.
I posted a couple pictures below.
You need to drill a 1/2 inch hole in each ski. measure from the front ski tip back 12 3/4 inches
towards the rear. Drill straight down, then when
the hole is through,lean the drill back at about 60
degrees to ream it out more. The front tab on the snowtracker should fit through here.
CHEERS
Thanks!!
Ok that makes sense. I didn't want to butcher up the skis unless I knew they needed to be. I appreciate the response now I can mount them this weekend and try them.
Thanks Again.
