tuneing
2006nytro
hello my dad has ben wanting and i want to get him tuneing software so he can tune his attack id like to know what the good ones are and advantages and disadvantages of them?
If you are not changing how much air the sled is getting or doing any mods that call for fuel, save your money. A good bang for your buck is a clutch kit. You will feel the differents. If you buy a PC III or PC V, you won't be able really tell if it did or didn't make a diffrents with out a test sled. If you do decide to get one get the PC III for the only reson being, there is a timing mod you can buy for it to increase timing and that is the only part that will get you alittle gain on a stock sled.
its not stock its clutched and piped and is there a mod to get more air to it? beside a tubo?
Do a search on how to make a ram air lid. You can add more fuel through the pod as well with just a lid, but if you get a PC III you just add it with that. If you get a PC III I can send you a map to get you started. But to do a perfect map you need a AFR gauge.
It's louder with a ram air lid and if you want to know the way it will sound just unclip the top half of the lid and open the front about a inch and crack the throttle and that's what it will sound like.
