snopro442
- Dec 10, 2007
- neenah wi.
- mod 08 nytro, 2-2007 phazers and a 2010 sno pro 500 speedwerx exterminator. new 2014 nytro for towing the snowcoach. 2015 Viper mpi turbo
who is making a block off plate???? I still want to use the stock location, I installed a skinz seat with the hauck husher muffler and would like to block off the tunnel, any info would be great thanks!
09nytro
schmidt bros motorsports makes a nice one , it works good to
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
Buy a .05" sheet of aluminum from McMaster Carr for $25 and make your own. The aluminum can be trimmed to size with a pair of metal sheers and fastened with pop rivets. http://www.mcmaster.com/#aluminum-sheets/=686o01
Alatalo
- Jan 11, 2005
snopro442
- Dec 10, 2007
- neenah wi.
I bought the seat used and did not get the panel.
Alatalo
- Jan 11, 2005
I would Have sent you mine since I have under tunnel but I just cut it up yesterday sorry.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
Alatalo said:Any possibility to use the block-off plate included in the Skinz seat kit...?
If not, you will likely have to make your own block-off plate.
I made my own for the combination of Skinz seat and Excell full exhaust.
I like the look of that...what excell is that and is the hangar pictured which looks bolted to the seatframe from skinz or?
That is not the Skinz exhaust mount. They come set up to take a factory style mount.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
I figured that...I want to know how he did that as Im considering the same
Alatalo
- Jan 11, 2005
sj said:I like the look of that...what excell is that and is the hangar pictured which looks bolted to the seatframe from skinz or?
That is the Excell full exhaust with the Excell silencer clamp and bracket, in the position where they would end up if using the standard seat and heat shield. On top of this is a small, home made bracket. This bracket holds two clamps that attaches the entire assembly to the seat frame. A little bit too bulky and prototypish for my liking, but I will not invest more time in this particular bracket since I will replace the entire silencer with something lighter anyway...
I can post more pictures, but not until Friday.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
I like it...and the tunnel bracing as well..
I am doing up an xtx and might take a page from your book....
yamahabandit
Great pics. Just when I thought I was done "upgrading " my sled , I see these pics and get another mod to do. LOL ! Will the suffering never end?
I thought when the weather started to warm up I'd just put the sled away and start the bike! No!!! Can't stop tinkering with the Nytro! Its a disease! Save yourselves!
sdclark
The Schmidt Brothers plate is a waste of money. It is just a square piece of aluminum I'm sure you can pick up locally for less $$$.
Thats it? What are the dimensions?sdclark said:The Schmidt Brothers plate is a waste of money. It is just a square piece of aluminum I'm sure you can pick up locally for less $$$.
