snowracer1000
what are you guys using have used a few products but i am not getting a real good shine close but not as good as i want. I have used rouge style compounds on it but just not shining that good. might my speed be to slow I was using a dewalt drill with a cloth pad.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Mothers works great.
bottlerocket
Wet sand it then polish ~ what a pain in the a** if you dont keep up on it.....
Wet sand, 1000 grit and work your way up, 1500, 2000....then use the rouge bars...any hand drill will work but make sure you keep the buffing wheel clean....also make sure you move it around applying decent pressure...then use a quality polish..I've used everything...Flitze, Mothers Mag n Aluminum, Mothers Billett, Never Dull...the best stuff I've found is Bush Super Polish...goes on easy, cuts well and comes off easy...no two ways about it though, you need elbow grease to bring out the shine. Te wet sanding and rouge bars just cut down on time...the final polish requires patience...the more you polish the better the shine....also if you wet sand try to go with the grain of the aluminum. good luck
xf800spro
Yea wet sand and then I used mothers billett on my crossfire and it came out mint, just thinking I have to start all over again when my xtx comes in is making my fingers hurt, but if you put the time in it it sure does look nice.
snowracer1000
thanks guys I use a polish called speedy it is pretty hard to find but it is the best i have found i will try the wet sanding thanks again.
TVBrian
- Mar 17, 2009
- Port Perry, Ontario
- www.portperrysnowmobileclub.com
shaddow44 said:Wet sand, 1000 grit and work your way up, 1500, 2000....then use the rouge bars...any hand drill will work but make sure you keep the buffing wheel clean....also make sure you move it around applying decent pressure...then use a quality polish..I've used everything...Flitze, Mothers Mag n Aluminum, Mothers Billett, Never Dull...the best stuff I've found is Bush Super Polish...goes on easy, cuts well and comes off easy...no two ways about it though, you need elbow grease to bring out the shine. Te wet sanding and rouge bars just cut down on time...the final polish requires patience...the more you polish the better the shine....also if you wet sand try to go with the grain of the aluminum. good luck
100% agree here.... mine still looks great after 1500 miles this season
bottlerocket
You polished it and rode 1500 miles without cleaning and polishing maintence? LOL
SledFreak
- Feb 7, 2005
- Ontario. Canada
What are "rough bars"?
bottlerocket
Polishing rouge which is bars of cutting compounds in different polishing cuts defined by color. You hold the bar on the polishing wheel and buff the metal ~ like puting wax on your rag for waxing.
Alatalo
All you need to know about tunnel polishing:
http://cubbyscustoms.com/
(look under questions section)
bottlerocket said:You polished it and rode 1500 miles without cleaning and polishing maintence? LOL
I only polish mine at the beginning of the season, same TVB....if you put a clear sealant on it it will hold the shine...I use Zaino clear seal, Zoop seal is supposed to work pretty well also.
TVBrian
- Mar 17, 2009
Yup, just wipe it down and dry it after putting it away and it's good as new. I'll repolish it this summer just cause I like that mirror look.
snowracer1000
I started polishing it is coming out really well. I found probably since I had an ok polish on it already i skipped the 600-1500 sand paper and just used 2000. It is working out well but don't skip the rouge bars. thanks for all the ideas and help
