stephenpen
That looks great. Thats the look I'm going for. Almost Chrome like
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
I have sanded it real nice and i keep polishing and i can only get it to look like an out of focus picture its not very clear just kind of fuzzy what am i not douing right?
RIKMAN did you polish your spindles also? Did you take the black reforcements off or polish around them? Either way it looks good.RIKMAN said:This is how she turned out.![]()
RIKMAN
- Feb 21, 2008
- Val d'Or, Qc
- 2020 Srx
bottlerocket said:RIKMAN did you polish your spindles also? Did you take the black reforcements off or polish around them? Either way it looks good.RIKMAN said:This is how she turned out.![]()
Yes i did polish the spindles. One day to strip paint off and sand to 1500 grit and 4 hours of polishing. And the reinforcements was installed after.
Mostly polished everything aluminium on the sled. (spindles,rails,tunel,risers)...
The worst part of it is to keep it shinny
shadow44
seal it..it will help out ALOT!
RIKMAN
- Feb 21, 2008
- Val d'Or, Qc
- 2020 Srx
I'll be trying Alcoa aluminium sealant http://www.alcoa.com/alcoawheels/north_ ... e_info.aspshaddow44 said:seal it..it will help out ALOT!
- Nov 1, 2009
- 2009 Phazer RTX
Does sealing it just mean waxing it basicly?
RIKMAN
- Feb 21, 2008
- Val d'Or, Qc
- 2020 Srx
http://www.alcoa.com/alcoawheels/north_ ... e_info.aspyamahas said:Does sealing it just mean waxing it basicly?
shadow44
In a round about way yes...but the sealers last longer than wax. Zaino ( what I use ) has a wax that i put on first, then a clear sealer that goes over top...it's just extra protection.
- Nov 1, 2009
- 2009 Phazer RTX
shaddow44 said:yamahas said:Does sealing it just mean waxing it basicly?
Where do you get this stuff? I googled them and their site wasent working for me.
- Nov 1, 2009
- 2009 Phazer RTX
shadow44
I got it from a guy in Toronto...i'll try to get his email...another good product I've heard guys use is ZOOP Seal...you can get it from Summit racing in the US.
basic700
- Mar 5, 2010
- Norwalk WI
- 2018 Sidewinder STX DX 146
2015 SRViper XTX LE
2009 Nytro XTX
Can you put the sand paper on an electric sander and just spray some warer on it once in a while??
shadow44
I found with electrice sanders they made swirl marks in the aluminum...best way is by hand IMO...sand with the grain of the aluminum...get a small bucket of soapy water and dip the sand paper in it...every now and then spray off the tunnel to keep it clean.
Stoli
I recalled reading this last year and thought I would post what we found that worked well. Mothers makes a "Powerball" and Mothers "Mag and Aluminum Polish". Ball was about $18 and polish was about $4 - also get a bundle of terry cloth towels for 4 or 5 bucks too.
Put some polish on the area to polish, use a drill and the Powerball, when it become a black color, wipe off with towel. You will go through a lot of towels. The more torn down your sled is the easier it was to get around some areas.
- 8K
