Turbo Apex crankcase breather?
MRFUSION
Peace River Alberta
Canada
2011 Custom Built Nypex
2008 Custom Union Bay 980 MM Chassis
What are my options for venting my crankcase, I know the Apex doesnt have the oil leaking issues like the Nytro but what line are you using and different routing options. Need a line that turns down and vents to the belly pan or out the chassis. Any ideas or pics would be appreciated. Thank you.
Shad
Hi Shad, Scott here. Lighting Pro years ago made a box for that issue. It mounted to the handle bar hoop. Blow from the lower nipple ran to it, then drained back to the valve cover. I still have it kicking around if you want to try it. Also I had a blow bottle that I got from a hot rod shop, another possible for you.
I hope you post some pics of this build when you're done. The attention to detail and craftsmanship on this thing is nuts! You've gotta feel proud of what you've created there.
Waay impressed.
