rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
Tarzan said:witch one of those can i use on my Mcx 19T turbo to Nytro with wastgate on topp?
The 19T and the GT2860 is pretty much the same size, it's always better to use a blanket that is too large than one that is too small.
Here's a link
http://www.horsepowerinabox.com/HPIAB2/category60_1.htm
MRFUSION
- May 19, 2008
- Peace River Alberta
- 2011 Custom Built Nypex
2008 Custom Union Bay 980 MM Chassis
You ever used or seen on of these brands (horsepowerinabox) rxrider. I contacted PTP on their blankets but they have no relief for internal wastegate. They recommend the flat wrap genesis style but Im not sure about it. Thanx Shad
Tarzan
- Oct 28, 2009
- Norway
- www.youtube.com
- Norway
Thanks Rxrider
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
No I have not, could not find the Subaru Speed shop in Australia I got mine from. I'll keep looking.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
After checking ebay and other sources all turbo blankets made for garrett gt25/gt28 looks almost the same. IMO anyone of them will fit as long as it's made for a GT25, GT28, and so on.
On the GT2860 I have no issues with the internal WG, actuator or the acuator rod. You can cut the blanket material if needed for clearance.
Lester
Cutting an X in the blanket for the wastegate works good.
Tarzan
- Oct 28, 2009
- Norway
- www.youtube.com
- Norway
So i can cut a hole for the wastegate rod and a X over the wastegate pin where the rod are connected?
[/img]
TWIN TURBO
- Aug 30, 2005
- Chicago IL.
- www.powerbygns.com
I don't think the blanket I'm talking about will fit that turbo. Made for a Garrett T25/T3 Housing
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
It's supposed to engulf the exhaust turbine housing.
You will have to cut a hole for WG leaver, enough for it to move around freely. Remove the actuator arm and install the blanket. Install the turbo into the sled.
Tarzan
- Oct 28, 2009
- Norway
- www.youtube.com
- Norway
Thanks Janrxrider said:It's supposed to engulf the exhaust turbine housing.
