Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Yes, I know it's an IHI turbo, Is there a very specific model number identified on the tag for the turbo that correlates to the model year '17?
Or must I dismantle everything as they are all different?
I figured NYTurbo might know....
Doc Harley
- Oct 17, 2016
- Here & there
Got it, I replace these intake clamps while I was there.
NYTurbo
THere was a revision to the IHI turbo in around 2018 , not sure what it was but expect it was to address the failures.
IT was not performance related as there was no tune updates
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Pre 18 turbos are the fast onesTHere was a revision to the IHI turbo in around 2018 , not sure what it was but expect it was to address the failures.
Doc Harley
- Oct 17, 2016
- Here & there
Don't worry I'll be getting all the updates done soon. HahahaTHere was a revision to the IHI turbo in around 2018 , not sure what it was but expect it was to address the failures.
Apparently some of them are going to have to find out the hard way. Hahaha. You're killing me.Pre 18 turbos are the fast ones
Turboflash
- Mar 18, 2019
- Southern MN
In the TCat line, 2017 thru 2019 used turbo 3020-386. Starting in 2020 thru current, turbo changed to 3021-932. No info on what was changed.
sideshowBob
Interesting I see the Sidewinders turbo part number was updated in the 2019 and later models....I would be curious what the difference was?In the TCat line, 2017 thru 2019 used turbo 3020-386. Starting in 2020 thru current, turbo changed to 3021-932. No info on what was changed.
Doc Harley
- Oct 17, 2016
- Here & there
NYTurbo, sees the change in turbo #'s as well, but nothing changed with tune.Interesting I see the Sidewinders turbo part number was updated in the 2019 and later models....I would be curious what the difference was?
Assuming both came from the same supplier, lots of speculation could come from this.
