Turbo Rx versus Turbo Vector
martini
langley bc
I love my RX turbo, but I am wondering for those of you that have ridden both, in terms of handling how do these 2 compare? How is the power on pump gas with the Vector?
thanks
even without the turbo i have ridden an 05 vector mtn and it handled worlds better than my RX. i think the vector makes 160 or 180hp on pump gas
thanks
If you want it to handle like an RS then get the wide front end. With the added width and heavier rate springs and 12mm sway bar it handles even better. It also drops your front end by about 1-1.5" :Rockon:
Vector Turbo
Running my Vector at 15 lbs boost on pump gas and it pullls hard with instance throttle response.
Head shim
Powder Lites Turbo kit
159 X 16 track
Mod rails and rear skid to keep from coming over backwards
Tunnel and coolers
Lightweight Battery and Box
Malher handlebar risers
Simmons skis
Lightweight Quiet Turbo muffler
http://www.powderlites.com/turbokits.html
