THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
- 2017 Sidewinder LTX LE
Sled runs good builds proper boost But at idle there is a sound like a hydraulic pump that is caveatting also don’t hear the unload blast of air that I should. Haven’t had a chance to look into it yet just asking to see if anyone else has had this issue and maybe get some direction
Thanks in advance
Thanks in advance
Turboflash
- Mar 18, 2019
- Southern MN
Center bearing in turbo?
Oil pump going out?
Water pump bearings?
Balance shaft bearings?
PTO stub bearing?
Oil pump going out?
PTO stub bearing?
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Not so sure you are going to hear this.. Maybe on a hard pull and let off, but generally these 998 turbos do not have much of any blow off sound.. None with turbotrash BOV.don’t hear the unload blast of air
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Sounds to me like a noisy turbo.
Can you hear it winding down after shutting the machine down?
You will only hear the BOV if your really listening for it on the big tunes with big boost.
THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
This is on a 2022 XTX with 200 miles on it 240/270/ 300hurricane have only run it on 240.
I have a 2017 set up the same
I hear the blow of on it and heard it on the XTX early on
The cavitation sound is definitely coming from left side
Going to take a look today and many swap blow off valves if I don’t find any thing obvious.
Confused
- Oct 12, 2008
- Mound, MN
- '21 Sidewinder LTX SE
'24 MXZ 850 Turbo R Comp
'23 MXZ Blizzard 850 ETEC
'24 MXZ Neo+ 600
'88 SnoScoot
Is it the noise the ROV makes from the crankcase vent hose in the air box? Pull the air box cover off and check it. Sounds like a pulsing sound.
THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
Under hood CAI
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
good idea.swap blow off valves
KnappAttack
- Feb 19, 2004
- Welch MN
Yep, this! Got to be the ROV sound on the clutch side the way they run it now.
As a test, remove the line going to the ROV and see if it goes away. Can run a line down to under the running board to test this out.
THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
It’s a pulsing coming from the roll over valve
It’s in a heated garage after every ride so it never had a chance to freeze other than maybe extended stops on the two rides I’ve been on
Lots of gunk in the hose
I think it’s going to get the bypass
THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
Has any one else experienced this
It’s like the oil tank builds pressure then the ROV release and then closes momentarily.
I almost think I could hear it doing this once down the trail but harder to nail down ounce the hurricane mountain pipe takes over on what you hear
Also that snot like substance in there can’t be good in the combustion department
My 17 is bypassed my wife’s 19 is bypassed going to do the 22 XTX I guess
Once done didn’t have to worry about.
Just curious if this is an issue others experienced
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Bypass it! No brainer.. Is the oil snot coming out the hose on the other side of ROV onto top of clutch guard?? Its eventually going to go onto your clutches..
Confused
- Oct 12, 2008
- Mound, MN
'24 MXZ Neo+ 600
'88 SnoScoot
I didn't bypass the ROV but added the BOP oil tank bypass which connects the oil tank back to the engine (valve/cam cover). I don't hear the pulsing noise but I also can't say I've paid attention. Maybe the clutch rattle is masking it.
THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
The sound I’m hearing can’t be ignored if yours was doing it you would notice. I have the BOP bypass also that I was going to install. Maybe I’ll try it and see if it stops the pulsing sound
- 6K
- 36K
