Turbo Vector Clutching ( help )
Turbo Perogy
Hanna Alberta Canada
Have a 05 Turbo mtn Vector ,frount mount alpine set up, woundering if anybody can tell me what rpm range on a good pull is ? I know the more boost i dial in the rpm rises as well. on a nice pull at 12lbs i am pulling 9400 -9600 rpm.
Rpm vector??
Scary guy?? You should be running 8500 RPM
You will not make power at that RPM cause running rev limiter!!
Put in 51 degree helix and throw some weight to it
Torque motor and even pulls hard at 8200
RPM kills rods which poke holes through engine block!!
we have a bolt on kit that works perfect, cost is 399.99 and includes cutom hh weights set to our specs for your application, sec helix, and a sec spring. jeff
I'm pulling 8000 rpm @ 9000 ft. with Yamaha arms weighted up with the heaviest rivets and one of the lightest springs Yamaha makes. I'm also running a straight cut 52 degree helix in my Hi-tech ER roller clutch. I can check to see exactly which spring and arms.
Heaviest rivets, stock arms, 45 helix. Can't remember if I changed the spring(sec) Just about perfect at 6000'. I would suggest you start by weighting up the arms, there is no way you have enough weight at that RPM (couldn't get your pm to work)
