rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
That's the idea, stronger bottom end and higher top speed earlier in the run, and you will be able to shift out the clutches. You will have to adjust your clutching to match the new gearing tho.
gotboost?
rxrider said:That's the idea, stronger bottom end and higher top speed earlier in the run, and you will be able to shift out the clutches. You will have to adjust your clutching to match the new gearing tho.
yes there not shiftin out all the way right now, i had the primary machined to get it to shift out all the way, but has been useless so far. i didnt think the 27 gear would be too steep. i had a dealer build the sled for me and thats what they put in. there set up is garbage tho. even the suspension set up sucks, way WAY to much ski lift, looks cool but slowing me down lol
4strokes are better than2
they must have change there # over the years used to be 210 at 12lbs boost & 250hp at 15lbs.i have a dyno sheet some where for my front mount tvec it made over 250hp at 15lbs boost.
gearing
I ve never seen a 27 tooth top gear for a yamaha in a stock chain case?
gotboost?
Re: gearing
not sure? it came with it
guba-jr said:I ve never seen a 27 tooth top gear for a yamaha in a stock chain case?
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
apex mountain crracing 174
apex blower 136 for asphalt racing
osp drag race sled (apex engine based)
mbarryracing said:gotboost? said:mbarryracing said:I'd double check those HP numbers, 15 lbs should get you way more than 205HP.
mc express claims 185hp on 91 oct fuel at 12 psi and 205 on 110 at 15
Just seems lower than it's potential, ballpark rule of thumb is around 10HP per lb of boost... Does it not come with an intercooler?
205 is still a hoot! Pretty tall gearing, too.
10hp per # of boost... on a 150hp baseline engine....
not on a 120hp baseline engine dude
gotboost?
MulotTurbo said:mbarryracing said:gotboost? said:mbarryracing said:I'd double check those HP numbers, 15 lbs should get you way more than 205HP.
how much on a 120hp motor?
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
Depends on what motor work has been done and the efficiency of the turbo system and engine package as a whole. Trail systems will gain the least of HP pr lbs of boost while race prepped engine will gain the most pr lbs of boost. My best guess is that you will gain approx 8 HP pr lbs of boost with the MCX turbo kit.
gotboost?
4strokes are better than2 said:here dyno sheet from mcx for the vec little over 200hp at 12lbs.
if thats for real my sled should go better. gearing has to be too high. didnt realize how much lower other guys were gearing theirs
turbine man
I have a 2005 turbo vector, with a 2560r bender rear mount i run 25/38 gearing at 20 lbs of boost i saw 137 on the gps, it is allso a stroker motor. i can run up to 9000 rpm rev limiter comes on at 9200. that 137 gps was on ice about 3/8 mile long Jeff
gotboost?
turbine man said:I have a 2005 turbo vector, with a 2560r bender rear mount i run 25/38 gearing at 20 lbs of boost i saw 137 on the gps, it is allso a stroker motor. i can run up to 9000 rpm rev limiter comes on at 9200. that 137 gps was on ice about 3/8 mile long Jeff
thats sick! what sorta stroker motor?
TWIN TURBO
I agree with rxrider, Your geared WayWayWay too Tall for 200 HP. You will go faster with stock gears 24/38. Ajust your clutching after you change gears.
gotboost?
TWIN TURBO said:I agree with rxrider, Your geared WayWayWay too Tall for 200 HP. You will go faster with stock gears 24/38. Ajust your clutching after you change gears.
yes im seeing that. i jus expected more from a dealer set up sled
mbarryracing
- Aug 31, 2007
- Springville NY
- 2006 Yamaha Attak Turbo
2015 SR Viper RTX-DX
1996 Vmax 600XT
gotboost? said:TWIN TURBO said:I agree with rxrider, Your geared WayWayWay too Tall for 200 HP. You will go faster with stock gears 24/38. Ajust your clutching after you change gears.
Most dealers aren't turbo setup experienced, although they will claim to be just to get your business. You need someone that is specialized.
Did you actually count the teeth on that 27 top sprocket or is that what they told told you? I don't recall anything bigger than a 26, either.
In any case, I agree you are not using your clutches at all with that tall gearing...
