ctp1528
I talked to randy at super torquer and he said you are the man for help. I just pickedup my 2009 apex gt has 6 miles on it . Was used at shoot out in old forge . what clutch should i run had 2 speed on nytro randy said was better then d/f 's or would you go to something diff. ? I want to pass my buddies 06 gt .thank s
Turk
Tech Advisor
Run either of em. After you buy something i can get you close but your gonna need to do some fine tuning. if your not comfortable or knowledgable with with tuning clutches buy a kit.
ctp1528
I have the 2 speed randy said stock spring what weights ? I have a red and silver from s /t . I have all the screws long and short plus all washers. thanks again for your help.
Turk
Tech Advisor
Try to find a black hc spring & start with 4 grams in heel & rest of weighht empty or go with stock spring & 3 gram bolt inner if you have 38/20,s.
Will take some trial & error to get this right as you have limited parts available.
ctp1528
The kit i have came from my nytro 08 rtx have a silver and red spring should i just order one from randy ? when you say heel do you mean the outer end that moves ? again thankyou for the help . going to ride this week
Turk
Tech Advisor
Red & silver is way too much spring. get the black from randy or maybe someone on here has one.
the kitchen
Here is what works on my 06 attak, black heel clicker primary, silver Yamaha secondary @ 6/3 twist, 38/20 weights, 3 grams center, 3 grams shoulder. RPM's @ 10900, this shifts out and back shifts very well. engagement is at 4000. Your gearing and track are different but this set up works very well on the attak.
