gamer1
- Mar 14, 2005
How difficult is is to change the A arm on the rtx, tweaked mine a little last night. thanks Todd
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
You'll have to remove the front plastic nose cone (6 phillips screws) then remove the air box. You'll need a 14mm & 17mm open end wrench and a 14mm & 17mm socket to replace either one of the a-arms.
Dano
gamer 1 said:How difficult is is to change the A arm on the rtx, tweaked mine a little last night. thanks Todd
Sorry to hear on the misshap, but kind of common at the beginning of the seasons with the skimpy snow. This happened to my RX-1 back in 02/03.
Be sure to check your bolts to see if they are bent as well since both top and bottom were bent on mine. A-arms went on back order just after I got my set so I would contact your dealer SAP for parts. I think the Vector a-arms will fit your Apex as well.
Good luck!
Dan
- 11K
