how do you like the curve skis
Work great with Slim Jim Dually on them.
Yamaharider74
- Dec 23, 2013
- theodore,saskatchewan
- 07 Yamaha apex
Hello
where did you get your blow off valve from I have a blow off on mine it is a 1 inch outlet on pipe that attaches to the bottom of the intercooler it looks like someone has added it on there it dumps the air I also have the pcv now that I got from hurricane I also got bigger injectors , fuel pump and a map for 12 pounds of boost seems to run good now sometimes dies at am idle but I know I need to turn up the idle a bitYes... the blow off Valve is a must..it runs pretty darn good... but you will need a Power Commander V - PTi to run it on a Supercharger.
Did you check out an of the other info on the build?? Here you can see the blow-off
Hello
My blow off came from MPI. I have never seen that before.. I would think it would work it just senses the pressure when you let off from the throttle bodies and dumps excess pressure.
Yamaharider74
- Dec 23, 2013
- 07 Yamaha apex
Cool thanksMy blow off came from MPI. I have never seen that before.. I would think it would work it just senses the pressure when you let off from the throttle bodies and dumps excess pressure.
maxdlx
- Feb 27, 2004
- Tipton, Iowa
- 07 Apex RTX
Tom .
Are you running autotune or ignition module with the PCV or both? Is the display really needed on a non-boosted sled? Looks good on yours.
Tom .
I am running the Auto-tune but not the ignition module. I have the head shimmed in the Supercharger and its not needed to take timing out so the ignition mod would be a waste. Display works for tuning, you can see the AFR numbers , RPM and Throttle Position to be able to go back to the map and make adjustments to the fuel as well as read the Auto-tune map to get the map closer to the numbers you need for boost or non boosted sleds.
maxdlx
- Feb 27, 2004
- Tipton, Iowa
- 07 Apex RTX
Peeling headgaskets and drilling a hole in exhaust were so much easier to understand. LOL
To be honest if its not boosted, dont bother.
maxdlx
- Feb 27, 2004
- Tipton, Iowa
- 07 Apex RTX
Even with airbox mod and a can
PCV with a tune for air box and pipe will work pretty good but i would try it without first. The early Apex where always rich as hell.
Tavon
- Dec 10, 2015
- Iowa
- Nytro
I run a sc but don't know much about them so please excuse the stupid question as I'm just trying to learn a bit. Why is the blow off valve a "must"? I would guess it provides a place for it to go when you let off the throttle since that's what I hear everytime I do let off or maybe it limits the boost?
It releases the boost or the motor gets stuffed with pressure as well as it helps stacked boost in the inter-cooler .. without the blow off it feels like the breaks are on when you let off on the it.
kviper
- Nov 7, 2003
- Oakfield WI
- 2012 MCX Turbo Apex
Your fuel controller reads boost pressure and adjusts fuel accordingly. When you chop throttle and boost drops slowly you are over fueling till boost tails off. A blow off valve dumps pressure almost instantly and stops over fueling= better off on throttle performance and better fuel milage. Never messed with the PC-V with auto tune and boost though does the V just work off o2 readings? I know the gems and all those use pressure.
- 7K
