wavemaster
- Mar 6, 2009
- New Hampshire
- SR Viper XTX, Nytro XTX, Phazer FX
I got the new Venom Air Box Kit in and installed it. I like it a lot. Install was easy (if you have the tools) and I can't hear and change in the sound in the shop.
It will pull cold air and that should help a lot.
Quality materials make up the kit and the instructions were fine.
sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
Thanks for the info. I have one on the way.
wavemaster
- Mar 6, 2009
- New Hampshire
Glad to help.
wavemaster
- Mar 6, 2009
- New Hampshire
Yes, you make the mod to your stock airbox.
Yeah, it can be hard to find, his site nav isn't the best. Homepage> Engine Performance> Intake Kits> bottom of page.
putz21
- Apr 15, 2013
- Tomahawk, WI
- '25 Sidewinder XTX LE w/EPS
'23 Sidewinder LTX LE w/EPS
Quality materials make up the kit and the instructions were fine. The template should be moved up 1/4" that would be my only correction.
Thanks for the tip on the template. Just got mine in the mail today and looking forward to installing it!
mnman309
I have mine on the bench, I will trim the template up a little to raise it up a little. But I did see that the instructions say to cut on the inside of the black line/marks, you are saying to cut it even short correct?
wavemaster
- Mar 6, 2009
- New Hampshire
The hole is simply a 3-1/4" so all you need the circle for is a center point if you are using a hole saw.
Sorry, I don't have a kits part picture I already installed it.
It consists of a nice aluminum flange with 8 screws
1 3" velocity stack with a clamp and cover/filter
3 velocity stacks for the intakes inside of the box
Instructions
Instructions
MartyV
- Mar 4, 2015
- Greenwood, ME
- 2015 Viper LTX SE
Thanks for the tip I'll be installing mine this weekend I'll try to get some pics up
Vilas
- Sep 6, 2014
- Urbana, Illinois
- 2014 Viper xtx, Thunder products clutch kit
Did you make him aware of the issue so he can change his directions? I'd hate to see people have problems getting their kits together.Glad to help.
On the template, you won't notice it while the airbox is apart, only when you go to put it together again, if too low the bolts hit inside making it hard to make it seal. It can go up at least a 1/2" and still have no clearance issues in the box or under the hood.
bleedyamaha
- Sep 28, 2013
- Northern Iowa
Can the ulmer venom intake kit be used with Stingrays air box mod ? Sorry if this is out there already.
wavemaster
- Mar 6, 2009
- New Hampshire
I'm not sure. All you do to the bottom is remove the plastic snorkel.
Vilas
- Sep 6, 2014
- Urbana, Illinois
What is the best way to order this from ulmer? Haven't had much luck getting ahold of them to place an order.
wavemaster
- Mar 6, 2009
- New Hampshire
I ordered on his webpage.
Vilas
- Sep 6, 2014
- Urbana, Illinois
I couldn't get that into the shopping cart, I'll try again. Thanks for your help.I ordered on his webpage.
sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
You can send him an email too. He is very busy being a one man show, but he will get back to you.
srxspec@gwtc.net
srxspec@gwtc.net
