ultra q or mbrp
i would like to here more about this cherry bomb how many pepole are runninng them with out any problems and may a part number and for the one that have them do you think they are as loud as mbrp
I cannot imagine that an MBRP could possibly be any louder than a Cherrybomb. You really need to put a restrictor cap on the Cherrybomb, otherwise it's too loud, and the lack of back pressure creates a hesitation at low throttle openings. Put on cap on the muffler, though, and it gets rid of the bog and makes the volume bearable.
As for a part number, it's 87507. Will bolt right onto your header, but you will need something to support the muffler. I used a piece of solid aluminum, machined to fit the muffler with a large clamp. Was really simple.
Like I've said, my plan is to get a shorter cherrybomb with a u-pipe and have the muffler dumping under the tunnel, facing forward. With a cap on the end, and under the tunnel where it will be dumping in the snow, it should be quieter. I'll let you know the results when I get it done. The 8" cherry was a special order, so it's going to take a few weeks to get.
Works for me
is it safe to say that a ultra q is not as loud as a mbrp.that is would make a better trail/populated area muffler and won't drive you nuts on a look trip.can you compare it to a 800 2 stroke with a dyno port big barker on it.
  • Install Instructions.pdf
i got the mbrp i agree with big time.but when you hammer on it you wont find a better sounding one.buy one youll like it
