Ntdedyet
Hello, I am new to the forum and I am trying to find out how to order a set of Up Bushman’s spindle bushing for my 2011 Apex XTX. Any help would be greatly appreciated!
2008lee
I know this is old but. I welded my Yamaha bearing kit unto the pivot links as after a short time the bearing holders were loose in relation to the pivot arm.That bearing kit is OK at best. I have it and there is still a lot of movement. I have since got some 1" machine bushings and taken out some of the vertical play (which helped quite a bit). But still from what I have seen not as tight as the UP Bushman kit.
It is not hard to do. Just knock the bearings out and then weld the bearing holder to the pivot arm. It takes out all the slop and lets the bearing work properly.
Picture?I know this is old but. I welded my Yamaha bearing kit unto the pivot links as after a short time the bearing holders were loose in relation to the pivot arm.
2008lee
