srxr700
- Feb 8, 2012
- cedar springs michigan
- 2006 Attack
2012 Vector
Can I reuse the upper chaincase locking collar?
I'm being told they are unavailable, and I'm not in a position to upgrade to the newer jackshaft right now. Sled has 3500 miles.
8JP-E7645-00-00
When doing the bearings, yes.
srxr700
- Feb 8, 2012
- 2006 Attack
2012 Vector
Thank you. Yes, doing bearings and seals. Replacing lower driveshaft for a spun brake side bearing. Is the upper bearing installation socket a "must" for setting torque? Or can I get away with counting rotations and verifying orientation?When doing the bearings, yes.
I just rotate it until there is no slop and get close to where you can bend a tab and then take screw driver and a rubber hammer and tighten one or 2 more spots. Does that make sense?Thank you. Yes, doing bearings and seals. Replacing lower driveshaft for a spun brake side bearing. Is the upper bearing installation socket a "must" for setting torque? Or can I get away with counting rotations and verifying orientation?
srxr700
- Feb 8, 2012
- 2006 Attack
2012 Vector
Just finished up my chaincase overhaul. When manually spinning the drive cog to verify everything is moving naturally, is it normal to have a decent amount of chain/sprocket chatter before adding oil?
Oh ya. But it should be smoothJust finished up my chaincase overhaul. When manually spinning the drive cog to verify everything is moving naturally, is it normal to have a decent amount of chain/sprocket chatter before adding oil?
srxr700
- Feb 8, 2012
- 2006 Attack
2012 Vector
Ok thanks. Threw me for a loop. Pulled the cover back off and everything is as it should be and smooth as butter.
Upper bearing replacement went great, thanks again for the help.
