Gone Blue
- Oct 11, 2006
- Howell, Michigan
I have my Chain case all apart on my 08' RTX and I am confused about whether I am suppose to have the thin o-ring behind the brake rotor spacers or not? Ulmers thread on track swap clearly shows that the sled had reverse and has the o-ring shown in the picture below.
My sled was stretched to 144" so it has had the chain case taken a part atleast once before. I do not remember seeing an o-ring when I took it all a apart. Looking in my Yamaha service manual it only shows the o-ring on a Nytro without reverse. Trying to determine if I need this o-ring or not????
However, I do now see the o-ring in the Yamaha micro fiche. It is #51 below?????? Dang. G.B
Brotherdan
- Sep 8, 2017
- Belmont,maine
- 2011 apex xtx blue, starr suspension,gytr front shocks,camso 1.5 track cut down, snowtrackers work in process,2003 rx1er originally 121 converted to 136"monoshock 2 ck136 rear suspension with clicker vector ltx shock,muffin works tunnel extension, seat concepts(wrp) seat,apex hooked handlebars converted to all underhood wiring,8"lake effect billet aluminum riser,gytr frontshocks,yamaheater hand warmer kit,rocks ridelite,rocks power supply, rocks heated bag,, tunnel braces,blue skid plate,garmin gps, aggressive snowtrackers on apex single keel skis,rollerski ski wheel kit,108 warthog studs&blue studboy backers,pioneer wheel lowering kit, dupont slides, 4th wheel kit,yamaha saddle, tank& windshield bags, powermadd led handguards, bar mount mirror kit, apex radiator& electric fan added, apex rear cooler,autometer temp guage, apex new style large diameter drive shaft with extroverts machined for chaincase,thunder products clutching,1987 enticer 340ltr 2100miles,1984 enticer 340,1996 wolverine 350,big wheel kit,winch,racks,k&n,full skidplates
The boring in the parts breakdown goes inside item#52I have my Chain case all apart on my 08' RTX and I am confused about whether I am suppose to have the thin o-ring behind the brake rotor spacers or not? Ulmers thread on track swap clearly shows that the sled had reverse and has the o-ring shown in the picture below.
Gone Blue
- Oct 11, 2006
- Howell, Michigan
Brotherdan, I just found the o-ring in the #52 spacer. Thanks! Man is it tiny. I guess it didnt see with some of the grime on the spacer. Thx again. G.B.The boring in the parts breakdown goes inside item#52
Brotherdan
- Sep 8, 2017
- Belmont,maine
No pro
no problem glad you figured it out.parts diagrams can be a little misleading&I just rebuilt my chaincase last year&was familiar with all of the parts.glad I could helpBrotherdan, I just found the o-ring in the #52 spacer. Thanks! Man is it tiny. I guess it didnt see with some of the grime on the spacer. Thx again. G.B.
Gone Blue
- Oct 11, 2006
- Howell, Michigan
Yeah that and the o-ring is so thin I didnt see it when I looked into the spacer. I didnt find it until I stuck my finger in the spacers and it came out on my finger when I pulled it out. I could just be blind, LOL. G.B.No pro
Deeppow16
- Oct 19, 2015
- Montrose, Minnesota
- 2016 Arctic Cat M8000
2002 Polaris 600 XCSP (Sold)
Yup its needed. I have taken nytro chain cases apart many times and its a part that can easily be lost or not seen when taking everything apart.
mp5
- Feb 14, 2011
- New Brunswick, Canada
- 09 Nytro XTX
Man, your picture is identical to the same one I posted 2 or 3 months back...asking the exact same question...lmao. Could not figure where that little bugger of an O ring came from as it was just sitting on my case when I was about to reinstall it all back together. Looked up the parts fiche and was still confusing. Posted it here with the same question, and 20 mins later had my answer....great site eh??
Gone Blue
- Oct 11, 2006
- Howell, Michigan
The picture I posted was from Alan Ulmers thread on track swap. I could not find the o-ring in my chain case when I took it apart nor could I find it in my Yamaha service manual for the chain case with reverse. So I was questioning whether my sled should have one. I ultimately found it in the large spacer behind the brake rotor. Yep great people on this site! G.B.Man, your picture is identical to the same one I posted 2 or 3 months back...asking the exact same question...lmao. Could not figure where that little bugger of an O ring came from as it was just sitting on my case when I was about to reinstall it all back together. Looked up the parts fiche and was still confusing. Posted it here with the same question, and 20 mins later had my answer....great site eh??
