Nytro270
- Dec 29, 2015
- Alberta
- 08 nytro with mcx turbo
Alright so I have a question for all you turbo savvy people out there, should I be able to draw a vacuum on the lines that appear to go to the throttle bodies? Would like to know before I go pulling the intercooler off to look for leaks
kennyspec
- Sep 30, 2009
- stonewall, manitoba
- nytro
I would assume you would be able to. there is a couple of lines that go to the map sensors. should be able to get a vac signal from there.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
yes my boost guage is connected to the nipples at the throtle bodies and reads vac untill it is under load alos vac when i let off that is how the blow off valve works it gets vac from those lines to open.
nate007
- Dec 25, 2006
- Iowa City, Iowa
- 1. '06 Apex -twin screw
2. '04 Redline Revolt 800
3. '09 Nytro XTX - twin screw
If you're looking to add a gauge, you may have to "T" into all of the throttle bodies, connect them together and then run it to you're gauge though. Didnt do that on one of my sleds a few years ago and the gauge fluttered around at idle. They'll pull a smoother signal connecting to all of them.
Sent from my SM-N910R4 using Tapatalk
