dylanjen9
I’m riding right now and the vector coolant pipe wore a small hole thru it and is leaking. Will hot light come on even if it runs out of coolant. I just keep adding coolant for now
Not necessarily.
Do not run that engine low on coolant or your repair bill can get very expensive.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
There is no low coolant light. Temp sensor needs coolant for an accurate reading since it is remote in the thermostat housing.
dylanjen9
Thanks that’s what I was worried about
Where is this coolant pipe located & how did it wear a hole in it.I’m riding right now and the vector coolant pipe wore a small hole thru it and is leaking. Will hot light come on even if it runs out of coolant. I just keep adding coolant for now
dylanjen9
On the back heat exchanger. Rivets loosened up and heat exchanger was rubbing on side of tunnel
Thank's for the replie.On the back heat exchanger. Rivets loosened up and heat exchanger was rubbing on side of tunnel
Banjo Man
- Nov 5, 2012
- Lake Barrington Il.
- 06 Vector GT. 15 Vector Ltx . 14 Vector Ltx
I’m pretty sure that your Vector will go in a shut down mode if overheating. My 06 did and same with my 15 although it hasn’t happened with the 15.
- 24K
