dmaxx
- Apr 5, 2006
- sw Michigan
- 2015 Viper RTX, 2012 Apex XTX, 2010 Vector LTX, 2000 AC Z-370..fast
- White Pigeon, MI
I posted this on the RS chat also. I bought an 05 Vector with 1000 miles on it that had sat for 2 years. It ran a litltle rough. I changed oil, plugs, cleaned carbs. Started hard, fouled plugs. Changed them and idled good for a minute then rough, backfired and oil began leaking, from the resevoir, I could hear it backing up into the resevoir. If you take the dipstick off, it will leak out. I put 3 qts in the block and a half quart in resevoir. Any ideas?
