superb
- Apr 10, 2004
- Ottawa, Ontario
- 2015 Viper turbo, 2013 Apex, 2012 Vector LTX, 2010 Vector LTX
Got to try out my 2010 Vector to-day. It has a excell header,ulmers clutch kit and is geared down one tooth on top. Pulls 8400to 8500 bottom to top, probably to low, but anyway, seems to pull good to 90mph and takes awhile to get to 100mph. I guess I was hoping for more, because my 2010 Apex would walk away from it, anywhere,anytime. Am I expecting too much , or is there more left on the table for this vector.
TRUE BLUE SINCE 1980
- Apr 11, 2010
- Central PA
- '10 VECTOR LTX
The Vector tends to give up at 90-94.
The motor is making its best power at 8200 rpm.
My 10 LTX goes 104 on the dream-meter at 8450 rpm. Stock gears
The Ltx has a lower gear then the GT. So... WE should be at the same ratio.
From the informatiom I got in here, They say to add 2 grams to each tip of the arms on the clutch.
That may take out 200 rpm's . I did this but did not try it yet.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
That sounds like the same story with my 2010 Vector. Once past 90mph it crawls up to and then hovers around 100.
I figure on a really hard pack surface I could squeek and wee bit more out if it. But seems to be the top end ive experienced.
That engine just sings at those speeds. It sounds like it could do that all day and it wouldnt phase it.
MS
MS
theCATman
- Feb 19, 2007
- WI
- Yamaha
In a nutshell... yes you're expecting too much.
The 3 cyl is a torque monster, not a HP making RPM screamer like the 4 cyl.
The 3 cyl was never, and probably never will be intended for big HP or MPH.
Enjoy it for what it is intended for, and use your Apex for what it was intended for.
superb
- Apr 10, 2004
- Ottawa, Ontario
VECTOR
Thank-you Guys
Thank-you Guys
- Apr 11, 2010
- Central PA
- '10 VECTOR LTX
I dont quite buy into the thought that lowering the gear will make a vector faster....
Quicker, yea , and also made your gas tank 10% smaller.
So.... I would'nt junk that stock gear yet.
What are your thoughts on the header?
superb
- Apr 10, 2004
- Ottawa, Ontario
Vector
I have nothing to base a opinion on. I never drove a stock Vector, but as winter goes on I will get a chance to run a stock one for comparison.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Clutching rarely gives you top speed gains, more low to mid speeds.
superb
- Apr 10, 2004
- Ottawa, Ontario
VECTOR
Update : My Vector is quicker than a stock one, by about 3 lenghts in a 100 foot run. Had it on the hard packed road to-day, it pulled a 108 mph on the speedo and was still pulling when I ran out of room. Still won't touch my Apex, but I am real happy with it. Happy New Year everyone.
iasledder
You can't compare an Apex to a Vector for acel or top speed. My Apex does 125/115
Vs Vector 105/99 speedo VS GPS. The Apex blows away the Vector all through the range. Both are show room stock.The Vector and my 600 Polaris 600 ltx are very comparable, bottom to top.
stubb111
- Feb 4, 2012
- Ottawa area
- 2009 nytro xtx
your expecting too much from your vector its only around 125hp and only rev to around 8500 rpm but it an awesome trail sled and competitive with apex on most trails but, not on any open areas.
Ronder
Buddy's f8 .long track. 1.6 track...Clutch balanced.. And weights........... Off the line I had him... Up to 60..
Eat my shorts ... scooter !!!
rocky18
- Jan 28, 2012
- Rockford, IL
- 1997 Yamaha 600 Venture
2012 Yamaha RS Vector LTX (R.I.P)
2018 Yamaha SR Viper L-TX-DX
- Just below the Cheddar Curtain
Where is your weight transfer control rod set? ThanksRonder said:Buddy's f8 .long track. Clutch balanced.. And weights........... Off the line I had him... Up to 60..
Rocky18, aka Mike
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
rocky18 said:Where is your weight transfer control rod set? ThanksRonder said:Buddy's f8 .long track. Clutch balanced.. And weights........... Off the line I had him... Up to 60..
Rocky18, aka Mike
He doesn't know......
Metallicat
I've had mine up to 118 on the speedo. Normally 104-112 though.
