harleyQc
Hi guys , on my 05 rs venture the reverse pops out when its not on that thrust. Top linkage adjustment is at 27... I got told that the lower linkage should be adjusted to remove loose. But how exactly . i get that i gotta unlock both lock nuts but then ... Do i have to extend the rod or retract it?
supposed to do it by feel according to the rx manual. supposed to adj till tight and then back off 1/4 turn.
harleyQc
Thanks alot. I ve never done it and want to make sure i dont mess anything or if i can get any tip of guys that done it !
harleyQc
would you do it with the track down or jacked from the floor?
i did it with my sled still on the lift but can be done on the ground.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
Manual says finger tight and back off 1/4 turn. I adjusted mine loose on my MP and Phazer where I would turn it to just barely touching and back off 1/4. This was for the finicky electronic reverse on those sleds. On my current RS Venture GT, I just bring it to light finger tight and back 1/4. Reverse works perfect. I think what the Yamaha engineers want is that there shouldn't be tension on the chain but not loose.
- 31K
