Gill_VK06
I have a venture multipurpose with the electric reverse not working I replace the actuator and it didn't make a difference. Is this a common problem and what is the usual cause. Any help would be appreciated.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
There is a fuse specifically for the reverse. If it checks out, there is a troubleshooting guide in the manual for the reverse.
Len Todd
Answered you in the other post that you made about this subject.
Gill_VK06
Ya thanks, got your other post.
Actualy we have not power to actuator and fuse is ok and followed trouble shooting guide. Thinking switch, ever here of that or ever here of anything else?
Len Todd
Have not heard of a switch failure. For testing, the switch you can disconnect it and measure the resistance across the switch. With the the switch on, you should see Zero Ohms. Any ohms at all or infinite Ohms, the switch is bad, if it is ON. If the switch is not easy to disconnect, then with the switch on, look for voltage across the switch. Any voltage across the switch when on, indicates resistance. Any resistance = bad switch.
