TURBLUE
- Nov 1, 2005
- Southern Alberta
- Sidewinder MTX
Anyone switch to the vertical steering on there sidewinder or older vipers? Like it better?
Being 6’5” I’m having issues with the bars being to low. My viper has the lay down steering so the longer riser moves you back further if you want to keep the post parallel with the riser.
I was thinking maybe a set of cfr crowbar handlebars will give a 1” vertical rise.
Does a guy need the goofy tripod off the 15-16 viper or can you go with the cat vertical steering without the tripod ?
rla1
- Jan 4, 2015
- saskatchewan
- 2017 sidewinder btx le
I switched to the vertical steering(goofy tripod) on my sidewinder .Yes,i like it better.I found a used one off of 16 viper mtx and followed the instructions on a thread on here.Do not know if cat one works or not or if it would require modifications. I also added a adjustable riser to it and original throttle cable is long enough.Anyone switch to the vertical steering on there sidewinder or older vipers? Like it better?
Norse
- Jan 1, 2019
- Sápmi
- Norway
- 2013 Arctic Cat M1100 HCR 162"
Boondocker turbo 250HP(sold)
2016 Yamaha SR Viper MTX LE 162"
MCXpress 270HP, lots of mods (sold)
2021 Arctic Cat M8000 Hardcore Alpha 155"
N/A (sold)
2023 Yamaha SW MTX LE 153"
M&M Racing 270HP, mods to come
I've tried both and I like vertical a lot better, I'm 5'8". Steering feels way more predictable.
TURBLUE
- Nov 1, 2005
- Southern Alberta
- Sidewinder MTX
Anyone have the setup kicking around cause they switch to flat?
dirtmover800
- Dec 28, 2011
What parts where needed when changed other then tripod? Any modification?I switched to the vertical steering(goofy tripod) on my sidewinder .Yes,i like it better.I found a used one off of 16 viper mtx and followed the instructions on a thread on here.Do not know if cat one works or not or if it would require modifications. I also added a adjustable riser to it and original throttle cable is long enough.
rla1
- Jan 4, 2015
- saskatchewan
You need the whole mtx vertical steering post with the tripod.Only mod was to the plastic shroud to make room for the tripod support bar.If you do a search "vertical steering" it explains how to do it, that is what I followed.
Grunt
- Nov 21, 2021
- Forest Grove BC
- 2016 Viper MTX
That goofy tri pod adds a TON of strength to the steering post. End of last season my buddy totally snapped his post off on a 16 m8000....
Robrstopr
Yes I had it put on day one. Never rode my sled stock or with the stock steering. That said im 6'1'' and all my prior sleds had higher bars. They still seem low for my liking but the rider forward is a must...Anyone switch to the vertical steering on there sidewinder or older vipers? Like it better?
- 9K
