Is the 2015 Viper primary clutch the same as on a 2012 Nytro XTX? I know the weights and spring is different, but is the Clutch the same? My xtx clutch has 12,00+ miles and I have access to a Viper clutch with only 1,500 miles. Thanks. Al
Yes it should be the same. I have swapped them before.
Thank you I figured it was the same but I understand the secondary is different but just needs some machining to run the 8D in belt
livewire_101proof
I've swapped my dad, and my brothers vipers over to 8dn belts and didn't machine, just need to use the set screws/shims on the back of the secondary to set belt height
