jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Have a buddy with 17 viper with everything stock. Looking to LOWER engagement rpm to 2900. I'm on the Sidewinder side of things and never had Yamaha clutches that are on the vipers. Simple as a different primary spring is what I'm thinking. He does not want to do a whole clutch kit. The stock spring seems like it would be soft enough looking at the Yamaha spring chart. BUT it's engaging around 3600. Thanks for any ideas.
Jon
Jon
DranttelSS
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
BOP soft start spring
SHARPMACHINE
- Feb 13, 2018
- West Michigan
- 14 RTX Viper SR
11 XRS 600
- W. Michigan
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Thanks guys! Just what we're looking for!
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
I tried changing out just the spring to lower engagement on my Viper but now run Schmidt Bros low engagement spring and small roller combination. The Schmidt bros setup (comfort clutch) works much better than just replacing the spring alone. Reduced roller diameter is the key if you want to do it right.
Redbeard
- Oct 14, 2011
- IN
- 2012 Apex, 136 M20, PB80
2008 Vector, 136 M20, PB80
What diameter roller did you switch to?Reduced roller diameter is the key if you want to do it right.
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
Schmidt's are custom made and If I remember right they are 14.7 mm. I ran them in my Nytro for years and they worked well. When I got the Viper I decided to try a few different setups without the smaller rollers but finally went back to them.
