yamaha06
My clutches seem louder than the Nytro. But it may be cause of the different panel vents.. definitely louder at slow speed and "clears" up as speed increases..
Ya that's how mine is, clutches are noisy at low speeds but get quieter once rpms increase.. Anyone figure a way to get the clutches a bit quieter?
klondike22
- Mar 4, 2013
- northern New York
- 15 SR Viper LTX SE
I hear metal rattling at low speeds also- no sound at idle nor when accelerating hard, nor at higher speeds. I hope its the clutch and will not be a bother!!
yamaha06
Ya sounds like mine, it's super annoying!! On my nitro I just had a noisy clutch when it would be idling, but as soon as you started moving it was fairly quiet, this viper clutch is loud and rattles a lot at low speeds and is driving me nuts. When cruising through a gas station or an intersection people look at you like your brand new sled is about to start falling apart.
Mine is not that loud. Maybe yours is the exhaust shield o6.
Reaper
- Nov 10, 2005
- Starbuck, Manitoba
- 2014 SR Viper XTX. COTC, Hygear 141 pro link.
Mine rattles the same at low speed them cleans up as soon as you get moving. Sounds like a rattling heat shield to me, have not investigated.
yamahaguy
Ride SAFE
- Apr 20, 2014
- 2015 Yamaha MTX LE with MPI
Stop going to slow guys! haha
Our clutches did rattle a bit going slow but after installing the mpi turbo and ulmer clutch kit it seams to be a lot quieter now, i don't notice the rattle anymore. hmmm?
I think some of these guys may have a cracked heat shield. I know you are just kidding and Yamaha clutches have always been noisy but if shield is cracked it needs to be replaced. Definitely inspect VERY common.
Reaper
- Nov 10, 2005
It's not the clutches, definately a heat shield or similar. It's triggered by a certain engine oscillation and vibrates.
yamaha06
Are you talking about the heat shield that's wraps around the header, that you have to take the gas tank off to get at?
tapex_07
- Feb 15, 2009
'07 Apex RTX SC2 MPI 128x1
Mines definitely clutch rattle. Goes up and down with rpm.. just annoying.
stingray719
I had gotten so used to it from my Nytro days I had not noticed it ........until I read this......thanks guys.......
tapex_07
- Feb 15, 2009
Haha my Nytro isn't nearly as loud...I had gotten so used to it from my Nytro days I had not noticed it ........until I read this......thanks guys.......
Yes.Look at the bend right side where it starts going upward. That corner and where it mounts to the side brace.
Nytro doesnt have all the vents for noise to come out like Viper. With covers off both the clutches sound same.
tapex_07
- Feb 15, 2009
I have almost the same vents on both.... still not the same, close with both off but the viper still seems louder.Nytro doesnt have all the vents for noise to come out like Viper. With covers off both the clutches sound same.
