new rob
- Oct 18, 2009
- peterborough ontario
- Viper rtx
a friend had his 15 ltx dx on its side the the other day , he let it sit for a bit before trying to start it no luck , he charged the battery overnight still no luck, he said the sled will cycle dash lights on and it just clicks , he said the click sounds like it's coming from the battery.??? Any ideas ???
Dinner
The clicking near the battery is the starter solenoid. Simplest thing first is to check for voltage coming out of the right side of the solenoid when in the cranking position.
johan
- Jan 19, 2015
- sweden
- Sweden
- Viper Xtx mcx 270
Starter maybe broken? mine did that after a kickback and the starter was locked
First try turning the motor by hand kill switch off turn counterclockwise at the primary clutch. It should be fairly easy go slow. Go from there.
mtotguy
- Jan 20, 2011
- Montague, Michigan
- 2016 Rush 800, 2014 Viper RTX, 1983 Excel 3
X2Starter maybe broken? mine did that after a kickback and the starter was locked
new rob
- Oct 18, 2009
- Viper rtx
Check voltage on battery ,solenoid,rolled primary all good. May be starter again and yes it just had new reflash may have been on its way out before flash !!
new rob
- Oct 18, 2009
- Viper rtx
Good to hear that!
