sledder454
okay guys I just picked up at 2014 viper this fall. I came from a 2008 nytro and 2009 nytro. Why are there so many issues with starting and fuel mapping with the viper? My nytros always ran flawless without any issues and as smooth as could be. This viper idles up and down inconsistent, and will sometimes stall with quick flip of the throttle. Also will stall if you let off the key to quick when it first starts, you have to hold it for a bit longer or give it a little throttle when cranking. This is the same motor as the nytro why doesn’t it run the same and why so many issues with this compared to nytro.
