Joshua Smith
- Jun 15, 2019
- michigan
- 2016 arctic cat xf7000 high country
Hello all you yamacat gurus. My plan is to put a barcode icebox air intake on my xf7000 but I would like to add velocity stacks as well to get the best flow into the boots. Does anyone know what size velocity stacks I would need? Any help is much appreciated!
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
This outta do the job nicely
Joshua Smith
- Jun 15, 2019
- michigan
Bahaha yes I'm sure that would git-r-doneThis outta do the job nicely View attachment 155828
Yam4Strokin
Joshua Smith
- Jun 15, 2019
- michigan
Awesome! Thanks for the heads up!
If you need pics or dimensions. I have mine out now. I know from past experience that there are Formulas out there for calculating the size and radius for most and where you want the power. Here is one we made for our Cannondales that Dynoed 3hp more than factory with same filter.Awesome! Thanks for the heads up!
Stock on right. Home made left.
Joshua Smith
- Jun 15, 2019
- michigan
Oh wow that's a nice piece of machined metal, you mill that yourself? What are the dimensions of your homemade one?Stock on right. Home made left.
Buddy made it on a Haas Mill in his garage but its for a Cannondale ATV so just a example. Was made using formulas found on internet. Will look around for them sometime.Oh wow that's a nice piece of machined metal, you mill that yourself? What are the dimensions of your homemade one?
Here:
https://redirect.viglink.com/?forma...profblairandassociates.com/pdfs/Bellmouth.zip
We found the closer to the throttlebody we put the bell the more hp and flow we got. Was Flowbench and Dyno tested. We got lucky right away.
