Studroes144
Studroes144
red dog
So 556 + 8 more gallons of fuel = 620 LBs
If I remember correctly my Apex is =690 LBs full of fuel
Does this sound about right ???
I haven't decided if I'm impressed or not ?
Hey Dennis. If you read this. HOWS THE BEEF ??? LOL
Yamadog
red dog said:So 556 + 8 more gallons of fuel = 620 LBs
Add Fox Evol shocks +4 lbs, add Tunnel bag full 20lbs, add rider + 200 lb ..............ADD TURBO - WHO CARES
My Rush is only like 475 and when its stuck I sit down and wait for passer by
sheetwright
So it is heavier then a Nytro??
http://www.snowmobile.com/manufacturers ... -1074.html
Or is that for a long track? I see they show 522 for the Nytro here +Gas= 571lbs aprox, or am I missing something here? I know this is dry weight compared to that D&D weighed sled. I also know the viper will be a better weight balanced ride, have a smoother suspension stock etc, but I thought these were going to be ballpark the weight of a 1200 doo... whithin say 10-15lbs?
http://www.ski-doo.com/showroom/mx-z/tnt/details
Of course I am going off of propaganda weights,a nd ry weights, but something seems off
Nytro40th
- Sep 19, 2007
- Amherstview Ontario
- 2014 SR Viper RTX SE
That is a long track not the short track.
sheetwright
Thank God!! Last thing I need to hear from Ski doo guys is more crap about weight, while I'm watching thme get pulled UGH
Nytro40th
- Sep 19, 2007
lmaosheetwright said:Thank God!! Last thing I need to hear from Ski doo guys is more crap about weight, while I'm watching thme get pulled UGH
SnowTech claims close to 500 pounds, dry.
rxwhopper
And the viper is suppose to be heavier because of the beef up
yukon yamaha
- Jan 30, 2008
- WHITEHORSE, YUKON CANADA
- 2008 nytro custom! 2014 viper custom
Hmmmm wow I think it is getting time to play the weight loss game hahah
Challange accepted Yamaha
stingray719
sheetwright said:So it is heavier then a Nytro??
NOT EVEN CLOSE, see this weigh in and pay attention to weight after ridden.......
Snowmobile weights
But please take into consideration it wasn't the weight that made the Nytro a pig it was how high the weight was on the sled. I cut a Nytro down to 541 wet (yes it can be done but costly) but it still wouldn't outhandle my Phazer because the existing weight was too high. The Viper has solved most of that issue.
Mtnviper
Vendor
So using the weight and capcity of fluids listed above the dry weight of the sled in the pic should be around
shown wet 556
coolant -10lbs approx
eninge oil - 8 lbs
2 gallons gas -12.4 lbs
chain case oil -.75 lb
shock oil -2 lbs (rough guess)
battery fluid -3 lbs (rough guess)
fluid total 36.15 lbs
Dry weight est 519.85, (sounds about right).
I'll be putting mine on a diet as I can afford it. I'm thinking that if I can get the 2 gallon wet weight to 500 lbs or slightly less, then the dry weight should be in the 460ish range which is fairly close to the Cat and Ski Doo mountain sled weights. With the reliability of a four stroke.
shown wet 556
eninge oil - 8 lbs
yukon yamaha
- Jan 30, 2008
I like the way you think Mtnviper. I think there is a lot of easy weight to pull out of the viper. In the hood alone I am guessing 10-14 lbs, (if any of you have held one you will know what I am talking about)
light weight battery, and a exhaust system, and headlight delete...those three things could drop you down 22-27 lbs and not break the bank.
Mtnviper
Vendor
Yeah, I agree looks like we'll have some choices for those looking to shed some weight out of they're sled
I already have the Lithium battery which is good for 11lbs. It's going to get a 153" powerclaw which will add some weight.
I'm going to pull the sway bar and install a 38" front end to help with side hilling and save some more weight at the same time.
Then from there, maybe some BDX rear arms (-4.5lbs), hood and or exhaust. From what I understand, the M1100T guys are telling me theres another 8lbs to be had by removing the reverse set-up. I guess it depends on how attached I get to having reverse, before I decide to remove it!
- 6K
