NickM
- May 11, 2020
- Driggs, ID
- 2007 Yamaha Phazer Mountain Lite
Hi all,
I'm troubleshooting a no-charging issue while running. 11.8 - 2.1 volts while running @ 5,000 rpm. Can get a few short trips out of a fresh battery, then it's drained.
Gone through all the basics first (battery, wiring, fuses), now time to get deeper. Where can I find the voltage regulator/rectifier, as well as the 3 white lead wires to the stator? Found a lot of helpful info on here about troubleshooting, but so for haven't had much like finding the actual components.
Thanks!
Thanks!
vanderrules
- Apr 7, 2020
- North Bay, Ontario
- 2007 Phazer FX (sold), 2008 Phazer GT(long tracked)
Take the left side plastics off and you will find the regulator just to the left of the handlebars.
