Yama-Crazy
- Jan 10, 2005
- S/E Michigan
- 2014 Yamaha Viper rtx
Is there an after market W-arm for rear suspension for an 05 Rage mines cracked near welds and I need either a new one or an after market or some advice...Where can I get a good deal on one and do I have to pull the whole suspension out to fix this? Any and all advise is appreciated..Thanks in advance!
maxdlx
- Feb 27, 2004
- Tipton, Iowa
- 07 Apex RTX
I have one off of a 05 warrior $75 plus shipping Maxdlx
PS can ship tomorow
PS can ship tomorow
maxdlx
- Feb 27, 2004
- Tipton, Iowa
- 07 Apex RTX
Hit submit to quick. Get a used one mine or someone elses and look on here how others have added gussets. It will save you the hassel in the future. Maxdlx
Yama-Crazy
- Jan 10, 2005
- S/E Michigan
Is yours in good shape no cracks? Yes I've seen how gussets have been added on a thread somewhere?
Yama-Crazy
- Jan 10, 2005
- S/E Michigan
And wondering do I have to pull the drive sprocket (Cogs) out or just the rear half of the track and drop it down?
maxdlx
- Feb 27, 2004
- Tipton, Iowa
- 07 Apex RTX
Mine is in great shape. The drivers stay in, but I'd pull the whole skid out to do the work. Check your lower shock mount while at it, they tend to be messed up when the w arm breaks. I have it too. Maxdlx
maxdlx
- Feb 27, 2004
- Tipton, Iowa
- 07 Apex RTX
I just checked same part number on yor sled and mine. Maxdlx
Yama-Crazy
- Jan 10, 2005
- S/E Michigan
Ok I'll check that out too and get back with you...might be a week or so tho..thanks!maxdlx said:Mine is in great shape. The drivers stay in, but I'd pull the whole skid out to do the work. Check your lower shock mount while at it, they tend to be messed up when the w arm breaks. I have it too. Maxdlx
Yama-Crazy
- Jan 10, 2005
- S/E Michigan
Is this suspension worth fixing if its gonna crack somewhere else and maybe again? Maybe I should just pull it and put in a used cat suspension or something..any thoughts?
Or maybe it just need some re-enforcing with extra weld?
Or maybe it just need some re-enforcing with extra weld?Groomerdriver
Yama-Crazy said:Is this suspension worth fixing if its gonna crack somewhere else and maybe again? Maybe I should just pull it and put in a used cat suspension or something..any thoughts?Or maybe it just need some re-enforcing with extra weld?
Depends if you have the $$ for a different skid. Me?..I'd look for a used skid on ebay. You're gonna keep welding that POS skid that's in there.
Yama-Crazy
- Jan 10, 2005
- S/E Michigan
I dont have the extra cash right now so I'm thinking about going the guset route and making it stronger..?
