happy1426
So should I just buy the rail extensions or look for a xtx skid?? Also what about gearing is it the same or different?? And curious what u guys with the 144 see for top mph?? Thanks
I think Muffin Works makes the tip up rail extensions and then you can by the XTX tunnel missing part and the rear heat exchanger.
happy1426
Was looking at them!! Will I loose a lot on top end??? Jay curious n what the xtx guys are running for mph??
karlburns
- Oct 3, 2013
- Anchorage,AK
- 2011 apex xtx
2010 vector ltx gt
I can't say what I've seen top end because I was paying attention to how fast trees, corners, bumps, etc were coming up. It was somewhere between oh #*$&@ and f-me though...
happy1426
Lol
ranger1
I have read on here on a few occasions that some are finding that the XTX's are a bit faster on the top than the shorter 128" version. Nobody can figure out why though. Kind of the same that my 136" Attack was faster than my 121" Apex. Not sure what the outcome would be if you just add extensions to obtain the length.
MX Dad 70
- Jan 19, 2015
- Apex RTX
Dealer friend of mine has a 2015 Apex XTX, he registered 109 with his GPS on groomed trails.
happy1426
That's not bad at all!!
The XTXs are geared different then the shortys.
happy1426
So rail extensions new track gears and tunnel extension pieces n rear heat exchanger that's about it... And re clutch obviously!! That's about it!
happy1426
Right on...and you may want the extended bumper.
maxdlx
- Feb 27, 2004
- Tipton, Iowa
- 07 Apex RTX
I have muffin works 121-144 tip up extensions and a muffin works tunnel extension on my 07 apex. I can get right at 100 mph GPS on perfect trails. I weigh in at 300 +/-geared up too. I am running stock gearing and Ulmer clutch kit that was for 136 set up I had. The muffin rail extensions bolted right on. All the holes lined up without having to do any drilling. Other extensiona I have used in the past always had 3 or 4 holes that weren't even close.
happy1426
Did you change to a different heat exchanger too??
maxdlx
- Feb 27, 2004
- Tipton, Iowa
- 07 Apex RTX
Used same cooler. Cut the elbow off the ends and wrlded them back on so this cooler would work. It was done when I got the sled. It was 136 when I got it and I changed it to 144.
