Warrior Heat Exchanger
Rear Heat Exchanger
Here are some pictures of my buddy's 05' Warrior with an E-bay heat exhanger. Fit like a glove.
The number off of the factory mountain cooler 'kit' package is:
8EP-RHECR-KT-00
The part number off of the exchanger itself is:
8FW-1241A-09
guys, the easiest fix for this minor, allmost not a problem is to lower the hole on the rear mount 3/4 of an in and the middle hole 1/4.
this will limit the travel so that the track can not hit the top.
some of you guys might be having a problem if you have installed over sized wheels on your skid, especially if it is an m-10. not sure what the expert does.
changing the angle of the suspension will change your transfer settings slightly.
steve, im gona talk you out of doing this guard so be prepared
