Cabinflyer
- Oct 13, 2019
- Ely-Tower area of Northern Minnesota
- 2016 Viper S-TX 137 DX, 2016 XF 6000 Crosstrek, 2007 AC 660T
I recently bought a 2016 Viper from a dealer. They claim the Flash was done. I'm a little suspect because the screws holding the hood on were oxidized and to me this indicated they were not recently removed.
So....how can you tell if the ECU was done? A friend suggested Yamaha keeps track of what sleds have what updates. Truth or myth?
Steve
Steve
Carla 123
- Feb 27, 2017
- Lester beach
- 2015 viper xtx boosted
17 zr9000 precision stage 3
Get another dealer to check your vin
Cabinflyer
- Oct 13, 2019
So what I'm hearing is the VIN can be entered into some database and it will tell you the date and version of the last Flash?Get another dealer to check your vin
Carla 123
- Feb 27, 2017
- Lester beach
It should
2015ViperMTX
- Feb 20, 2019
- Iowa
- 2015 viper mtx
Call Yamaha 1-800 number they can run your vin and tell you. But the dealer has to submit to Yamaha the flash was installed, which they are supposed to do after they do the flash
Actually as they do the flash its entered right away since its done over the internet.
2015ViperMTX
- Feb 20, 2019
- Iowa
- 2015 viper mtx
Here is my experience. I called Yamaha they ran my vin, they said the newest flash was not installed. I called the dealer he said the newest flash was installed and he had not submitted it to Yamaha at that time. Maybe I will call Yamaha again on Monday and check to see.
Thats impossible. Only way a dealer can get the new flash to put in your sled is to submit the work to Yamaha. PM me your Vin.Here is my experience. I called Yamaha they ran my vin, they said the newest flash was not installed. I called the dealer he said the newest flash was installed and he had not submitted it to Yamaha at that time. Maybe I will call Yamaha again on Monday and check to see.
hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
With my experience if you still have the 16 flash and it runs good I'd leave it. Mine was awesome untill they started flashing it
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
- 2016 SR Viper RTX DX
Former Yamaha sleds:
2004 Venture 600 2002 SX Viper 700
1997 Vmax 600 SX 1994 Vmax 600 1989 Exciter
1986 Vmax 540 1986 Phaser 1981 SRX 440
I will not have my 2016 reflashed, to many unsatisfactory results. It has no major issues as of now so no resin to risk it.
Only reason I did it and its a big one is the latest flash prevents kickbacks which will ruin your starter and put metal into your engine. Just so you know.
Cabinflyer
- Oct 13, 2019
This is the reason I want it done. My friend had a kickback on her 2016 (same model as mine) and it cost he big $$$Only reason I did it and its a big one is the latest flash prevents kickbacks which will ruin your starter and put metal into your engine. Just so you know.
sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
The last flash also took out a dead spot just off idle that made it a pain in the butt to drive slowly around the yard or garage.
On a stock sled there also was a performance increase especially at acceleration and fuel saving at mid range. Its really too bad they have a stall issue and they had to do the starter protection with what can be a two try starting process.
Froggy
- Apr 29, 2016
- Kipawa,Quebec
- 2020 Winder LTX SE 17600 km and counting
2016 Viper LTX LE 23986 km sold
2015 Viper LTX DX Wife's 22500 km sold
2010 Vector LTX GT 25000 km sold
2024 SRX Leftover 3700 km
Cabinflyer, They don't remove the hood to flash it, remove right side panel and open panel in front of right knee and plug connection is there beside oil tank.
