Blue shadow
Running a 300 hurricane tune with no leaks on the intake or exhaust side.Running stm weights at 84 grams.I am trying to find a way to hold the wastgate back so I can reach 20 psi before it opens.It is taking about 4 seconds to reach 18.9 psi .Running 660 ft snow drags .I remove the wastgate and at 5 psi it starts to crack open.What is the spring pressure on the stock wastgate on a sidwinder ?thanks
0degC
- Jun 5, 2009
- Sudbury, Ontario
- 2023 SRX, 2017 XF 9000
The stock waist gates seem to vary 5 psi crack pressure is on the low side. You could shim it a bit, put a washer under bracket on each mounting bolt to pretension the spring a bit. Also are you sure no boost leaks? Are you running a header? You could also purchase the dual port waste gate TD and Hurrince are selling that will control boost better with matching tune... but pricey.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
My waste gate cracks at 10PSI when I checked it before. 5 PSI is way low. Wonder if the spring is broke inside.
sledding rocks
how about using the bolt that td sells for semi locking the waste gate ?The stock waist gates seem to vary 5 psi crack pressure is on the low side. You could shim it a bit, put a washer under bracket on each mounting bolt to pretension the spring a bit. Also are you sure no boost leaks? Are you running a header? You could also purchase the dual port waste gate TD and Hurrince are selling that will control boost better with matching tune... but pricey.
0degC
- Jun 5, 2009
- Sudbury, Ontario
He could for 660. I would want to test with c16 and or start with locker out at least 80-90tho. I have only tested a couple of waste gates so not 100% sure but found about 6-7 psi crack pressure. His spring is on weak side it seems, would still think would get to target of 20. My bet is a slight boost leak combined with weak spring. And if has header all this is a different story.how about using the bolt that td sells for semi locking the waste gate ?
Blue shadow
The stock waist gates seem to vary 5 psi crack pressure is on the low side. You could shim it a bit, put a washer under bracket on each mounting bolt to pretension the spring a bit. Also are you sure no boost leaks? Are you running a header? You could also purchase the dual port waste gate TD and Hurrince are selling that will control boost better with matching tune... but pricey.[ If I go with the 4 port controller solenoids and turbosmart 1wg-75 what spring perssure should I get ?
Blue shadow
That with twin port wastgate
sledding rocks
please explain about header .He could for 660. I would want to test with c16 and or start with locker out at least 80-90tho. I have only tested a couple of waste gates so not 100% sure but found about 6-7 psi crack pressure. His spring is on weak side it seems, would still think would get to target of 20. My bet is a slight boost leak combined with weak spring. And if has header all this is a different story.
Blue shadow
Stock header for now
Blue shadow
thanks ,I just check another sidewinder with the same results.My waste gate cracks at 10PSI when I checked it before. 5 PSI is way low. Wonder if the spring is broke inside.
0degC
- Jun 5, 2009
- Sudbury, Ontario
Stock waste gate opens at 18 or so with header, even if a 20 tune.please explain about header .
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
Are you sure you have no boost or exhaust leak? Mine makes full boost in less than 1 second I think, gotta double check some data logs
Blue shadow
I just did a leaking down again and no leaks on both intake and exhaust.The only air I can feel is what is coming out of the exhaust were the wast gate goes back and forth.I did 5 runs and all showing the same on the gopro.It takes 4 seconds to reach 18.9 psi.Is there anybody running the 4 port controller solenoid and turbosmart 1wg-75 with twin ports that Dave herricane sell?What spring crack pressure are you using ?thanksAre you sure you have no boost or exhaust leak? Mine makes full boost in less than 1 second I think, gotta double check some data logs
Blue shadow
If your running the stock wast gate what did you do for it to only open at crack pressure at 18 psi?thanksStock waste gate opens at 18 or so with header, even if a 20 tune.
Blue shadow
