Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
2 guys on the french chat lost their 2 bolt under the turbo!
dsimonRX1
- Dec 17, 2003
- Cascade,Ia
- www.american-iowa.com
This will be something we all need to check at fairly frequently. Any suggestions how to make sure they don't come loose?
Kevin
- Dec 20, 2006
- Ottawa Canada
- Sidewinder
that's not good
Wire them? Nordlocks? Stage8? Can you post a pic of them?
- Apr 14, 2003
- Hessel, Michigan
I am going to put lock-washers on...but the wire tie would be better.
Kevin
- Dec 20, 2006
- Ottawa Canada
- Sidewinder
Could you take the two bolts out, drill holes in the heads and wire them together?
JestersYamacat
- Feb 20, 2013
- 2017 Sidewinder LTS-SE Black/ Orange, 2012 xf1100lxr Green
- Kanata, Ontario
In truth any part with this much heat should go through several heat cycles and re tightened. We had these same issues with all of the cats turbos. They get wicked hot and with vibration they loosen. Follow the heat cycle process and you should be good. Two previous turbos and more than 10 in my group and all have done this with great results. Cheers
Jester
Jester
Yes Kevin that is always a option. Nordlocks are much easier. NosPro bring that bolt over I have some Nordlocks for you to try.
http://www.nord-lock.com/bolted/watch-the-new-junker-test-video-here/
I would still retorque after getting it hot though.
Kevin
- Dec 20, 2006
- Ottawa Canada
- Sidewinder
Anyone know what size those bolts are?
bleedyamaha
- Sep 28, 2013
- Northern Iowa
Great video. Nord-lock looks like a great answer.
I was sold on them with Husqvarna XP chainsaw mufflers falling off. This or spotwelding was only thing that worked. Later Cannondales which had a "issue"! You can get them at McMaster Carr or a lot of Hardware places like Fastenal.Great video. Nord-lock looks like a great answer.
Kevin
- Dec 20, 2006
- Ottawa Canada
- Sidewinder
anyone know the size of the bolt head then?
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
I used stage 8's on my nytro turbo...and nordlocks on my 1100 turbo..I think I have some nordlocks left
kylechargerrt
- Dec 8, 2013
- Scotland Ontario
- 2017 YAMAHA SIDEWINDER LTX-LE
1998 MACH-Z
Is this bolt accessible without pulling muffler?
Sent from my SM-G920W8 using Tapatalk
