13mm what does that tell those of us who have been working on Yamahas? Tells me a lot!2 bolts. 13mm
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Great info steve,i will look into this as well. thanksI was sold on them with Husqvarna XP chainsaw mufflers falling off. This or spotwelding was only thing that worked. Later Cannondales which had a "issue"! You can get them at McMaster Carr or a lot of Hardware places like Fastenal.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Ya,whats up with 13 mm stuff anyways,when we were setting my sled up for the drags,every bolt seemed to be 13mm or 11mm,the slider lock bolt nut is 11mm and hard place to get a wrench into,i had to grind down a 7/16th wrench to applicate it.13mm what does that tell those of us who have been working on Yamahas? Tells me a lot!
- Apr 14, 2003
- Hessel, Michigan
Before the trip to Houghton for the TY ride, I took out my bolts, put High Temp red gasket maker on the threads and tightened. No issues
Will be bringing it in for the bulletin they released Saturday
SaskAttack
- Jan 4, 2006
- Corning,SK.
- 17 Sidewinder XTX-SE
- Corning, SK. Canada
What bulletin?
Turbo 998
- Mar 30, 2016
- LeSueur MN
- 2017 Yamaha Sidewinder LTX LE, 2014 Yamaha Viper LTX, 2001 Arctic Cat ZR800, 2- Yamaha SS440, Yamaha Enticer 250, Scorpion lil whip, Scorpion Super Stinger
- yes
Mine were loose also put nordlock washers on them hope that works.
- Apr 14, 2003
- Hessel, Michigan
What bulletin?
Bulletin being emailed to me. I will post it when I get it.
- Apr 14, 2003
- Hessel, Michigan
Arctic cat bulletin BS201708
Torque bolts to 50 ft. lbs.
AXR
- May 5, 2007
- Central NY
- Current: 2017 SideWinder L-TX LE
Past: 2015 Sr Viper R-TX SE, 2008 Apex RTX, 2002 Sx Viper, 1997 XTC 600, 1991 Doo Formula Plus.
Thank You!Arctic cat bulletin BS201708
done dooin'_winder up
- Dec 6, 2016
- saegertown pa
- 2017 sidewinder stx 137 dx
mine were loose, ordered nordlocks on ebay, came today
AXR
- May 5, 2007
- Central NY
Cats service bulletin on turbo bolts coming loose.
Service Bulletin
Date: December 16, 2016 Product Line: Snowmobile
Bulletin No: BS201708 Subject: Turbocharger Mounting Hardware
Affected Models: Specific 2017 9000 models
NOTE: Refer to Cat Tracker Online to obtain the list of affected VIN’s from your inventory
by selecting the “Service” tab, then the “Bulletin Display” tab. Specific criteria is required to
be selected. Example: Bulletin Type-All, Product Type-SNOW, Bulletin Number BS201708 and
Bulletin Year 2017.
Condition: The three cap screws securing the turbocharger to the right-side spar were
torqued incorrectly during the assembly process.
Solution: Torque the three cap screws securing the turbocharger to 50 ft-lb according to
the instructions below.
Instructions:
1. Remove both access panels; then loosen the two quarter
turns securing the hood. Disconnect the hood harness
and pull the hood forward and off of the snowmobile.
2. Remove the five screws and washers securing the turbo
heat shield to the turbo. Remove the shield and account
for the isolator washers under the exhaust pipe heat
shield. See Fig. 1.
Fig. 1
YM-181
3. Apply a small amount of penetrating lubricant to the
threads of the front clamp; then loosen the nut securing
the exhaust pipe clamp to the turbo. See Fig. 2.
Fig. 2
YM-182A
4. Remove the six torx screws securing the resonator to
the turbo; then remove the spring securing the resonator.
Remove the resonator and account for a gasket. See
Fig. 3.
NOTE: A long T50 ball head torx bit (p/n 0644-623)
will be needed to remove the torx screws.
Fig. 3
YM-154
5. Remove the nuts and the resonator bracket securing the
rear portion of the right-side spar to the chassis; then
only loosen the cap screws and nuts securing the front
portion of the spar. Remove the two screws securing the
front resonator bracket to the spar. See Fig. 4.
Fig. 4
SNO-889
6. Using a regular 13 mm socket, tighten the outer cap
screws to 50 ft-lb; then using a 13 mm swivel socket
and a six inch extension, tighten the inner cap screw to
50 ft-lb. See Fig. 5.
Fig. 5
YM-212
7. Secure the turbo and spar assembly to the chassis using
the existing resonator bracket, screws, and nuts.
Tighten to 12 ft-lb. See Fig. 6.
Fig. 6
YM-163
8. Position the exhaust gasket between the turbo and the
resonator; then using the long T50 ball head torx bit,
secure the resonator to the turbo using the existing
screws. Tighten the screws to 9 ft-lb then to 18 ft-lb in a
crisscross pattern. See Fig. 7.
NOTE: Apply a small amount of anti-seize lubricant
to the threads of the screws.
Fig. 7
YM-154
9. Align the exhaust pipe flange into recess of the turbo
making sure it will seal properly; then secure using the
existing clamp. Tighten to 6.1 ft-lb. See Fig. 8.
Fig. 8
YM-182A
10. Install the turbo heat shield and secure using the existing
cap screws and washers. Tighten securely. See Fig. 9.
Fig. 9
YM-181
11. Install the hood and both access panels.
Warranty: A labor allowance of 0.5 hr will be paid per affected snowmobile.
NOTE: It is required to enter the current mileage of each affected model.
! ATTENTION
To ensure that the necessary service work is completed in a timely manner and that this issue can be resolved, Arctic Cat is requesting that all service
work be completed prior to December 16, 2017. All warranty claims directly related to this issue will not be honored after December 16, 2017, without
prior approval.
Printed in the U.S.A. ®™Trademarks of Arctic Cat Inc., Thief River Falls, MN 56701 1216
Service Bulletin
Bulletin Year 2017.
Instructions:
shield. See Fig. 1.
Fig. 1
YM-181
Fig. 2
YM-182A
Fig. 3.
Fig. 3
YM-154
Fig. 4
SNO-889
Fig. 5
YM-212
Fig. 6
YM-163
Fig. 7
YM-154
Fig. 8
YM-182A
Fig. 9
YM-181
! ATTENTION
prior approval.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I tol
I told this to my dealer today and they now nothing about it. Should be the same bulletin for our sidewinders.
Service Bulletin
Bulletin Year 2017.
Instructions:
shield. See Fig. 1.
Fig. 1
YM-181
Fig. 2
YM-182A
Fig. 3.
Fig. 3
YM-154
Fig. 4
SNO-889
Fig. 5
YM-212
Fig. 6
YM-163
Fig. 7
YM-154
Fig. 8
YM-182A
Fig. 9
YM-181
! ATTENTION
prior approval.
AXR
- May 5, 2007
- Central NY
Yea you would think. Just one more thing Yamaha is slow to the party on..
1100saber
- Dec 17, 2016
- northern ontario
- 2017 Sidewinder LTX-SE
- AlliedPerformanceShoppe@outlook.com
do you have the pics too?
Kevin
- Dec 20, 2006
- Ottawa Canada
- Sidewinder
Which Nord-locks did you guys get?
M10 with 16.6mm od?
Loose or glued?
M10 with 16.6mm od?
Loose or glued?
